desduggan
Everything posted by desduggan
  1. Yep - jacked it up and put the positive from the decent battery onto the terminal on the starter and earthier the other one. Then there was enough power for the alarm to unlock
  2. Thanks chaps never thought of that - ill drag it out of the lock up and give it a go..
  3. Oh - and it doesn't have locking pins on the doors (so I can't bend the door to pull it up)...
  4. Had my VR stood for about 6 months and the battery has gone dead flat. Problem is - none of the keys operate the locks (always used the alarm which won't work due to the flat battery!) I thought I'd be a me to remove the grill and get to the bonnet catch. Removed the grill fine but can't get to the @*%#ing catch. Any advice (other than breaking a window)?? Cheers Des
  5. I live in Stalybridge and the car's currently in my mates garage near Old Trafford - I can have the car wherever works out best. I'll PM you my number..
  6. Cheers all for the reponses. GazBarber - see you're in Manchester too - can you recommend anyone local?
  7. My car was running fine, then due to being unused for a while the battery went flat. I jumped started it and run round in it for a day and it was fine. To make sure the battery had a decent charge in it, I removed it and gave it a good charge. When I put the battery back on it wouldn't start... It turns over fine but wont fire up. I checked the fuel pump relay and fuse and they're fine. An auto-electrician has looked at it and was convinced it was the transponder reader. He's replaced that and it's still not right. If the battery is disconnected then reconnected it will start. If you turn
  8. Thought so - cheers for the quick response
  9. Hi all, Maybe a daft question but will the clocks from a mk3.5 cab (2litre) fit a VR6? Also - do all the later mk3 cab clocks light up blue like the mk4? Cheers
  10. Probs a daft question, just want to check - will the standard rims off an OBD1 fit an OBD2 (i.e. 288mm discs on the front?) Cheers
