bpm
About bpm
Ireland
I've got a similar issue at the moment. VAG-COM shows no errors on it and at about 15% load it hesitates like it has no fuel, Once you let go of the accelerator, the RPMs go back to normal idle and all is good. Also on full load it runs fine!
Engine sometimes needs excessive cranking to start
bpm replied to Lukey.'s topic in Engine Maintenance and Problems
I had a similar issue when I first put the VR6 into the mk2. turned out it was the ignition switch that was causing it -
What colour is the smoke?
Does the fuel pump prime when you turn on the ignition?
Hi all, What is involved in converting an early OBD1 engine to an OBD2 engine? Intake Manifold, MAF, Throttle body, loom and ECU ?
Just wondering the same if anyone has used one or even fitted one? Hard to fit? (Especially in a mk2?)
Sounds like a good idea. I'm open to ideas on both
Hi all, I have a mk2 Track Car thats in need of new suspension. Keeping in mind budget, what do people recommend I fit?
Hi all, I've got a mk2 VR6 OBD1 track car. Its an ex-rally car 1.8 16v that I recently put the VR6 into. I'm now looking to upgrade the suspension. There's two options, coilovers or race springs and adjustable shocks. Anyone have opinions on it?
corrado VR6 conversion help... OBD1
bpm replied to dene4638's topic in Engine Maintenance and Problems
I'm guessing that you haven't jumped d8 to E2 on the back.. -
If you're still running a 4 stud pattern then mk2 gti wishbones should do...Did you break one???:-#
There's a fuel pump relay in the fuse board (can't remember which one off hand) and also when I first transplanted my obd1 vr6 into the mk2, the ecu wasn't getting a proper ground, stopping the car starting. You also might check the ignition switch too, it might not be providing power to the fuel pump relay.
I read somewhere that the connecting wires (4 pin) are in a different order, so thats why they don't work. I've a track car and wired up an on/off switch to it and it works fine. granted this isn't the answer you're looking for!
Just to update you guys, it turned out that the exhaust had come apart at the join between the decat pipe and the centre box, giving no back pressure at all. A simple answer for something weird.
