RIMZ-INC
Everything posted by RIMZ-INC
  1. Ok ive solved pretty much all of my other problems. But now its developed a squeal and squeak mixed in with a cluncky sound around the pully area. Its usually as it gets warm. I cant see anything and the belts feel tight. has anbody any ideas? Lee
  2. Its not using oil at all really. I have a feeling it may be stem seals. I didnt own the car when the work was done so im not sure what they actually changed when they did the HG. Lee
  3. Is £50-£60 about right for an ISV? seen a few on ebay. Lee
  4. Vapour evapourates in the air but this lingers and you can smell oil. It had a new head gasket about 10k ago as a garage snapped a bolt and it was a head off job. It had the full works done to it so im hoping its not rings. Lee
  5. The Smoke is white, its defo oil smoke. Its only every now and again and when i pull away in a low gear. Lee
  6. Hey guys. Ok ive a J plate VR. There is a light on the dash. its a circle with 6 lines around it... ( O ) bit like this in orange. does anyone know what it means? I think it may be brakes but im not 100% sure. Also I have a stalling issue when i dip the clutch, is this the idle stabalization vale? And I have a small amount of smoke out of the exhaust once its warm but its only every now and again.. is this piston rings or a breather? Hope you can help? Lee
