fv8
  1. Hi Guys, ritght been on a mission today to find out what is actually wrong with car.As recommended i checked the recesses which were all ok as i did blow them out before i drove back from germany. I also took off the coilpack and dismantled it and found slight corrosion which i cleaned but no joy still stuttering!!! So i took it to a local garage where they did a diagnostic on the vehicle and it come back with a fault "IDLE AIR CONTROL VALVE". Now i'm not sure how this works and if i can dismantle this to see inside. So is it possible for me to take this apart so i can clean it or will a new/u
  2. Thanks Guys, i'll check that first thing tomoz. And let you know how i get on!!
  3. I would appreciate some help with this or some advice. i've just recently come back off holiday in germany and while i was there i had the car valeted. But when i picked the car up i disvovered there was a stutter and a occasional backfire coming from the engine compartmant. The stuttering comes when i pull off mainly from below 1000 rpm upwards to 2500 rpm!?!i've blown out all the electrical cables but no difference. Has anyone got any suggestions on what i can do next???or any ideas what this could be?? Thanks in advance
