Leon R
About Leon R
London
Dilemma! High mileage buying opinions
Leon R replied to Leon R's topic in Engine Maintenance and Problems
Looking at the Forum, Pistonheads etc, it seems quite difficult to get a low mileage, looked after one with ideally no rust. But I'm also a little fussy as I don't want it to have been played with, i.e. oversized dodgy wheels, exterior mods etc... There was one near where I live in North London, 134k, chains done with rust all over the rear arches, tailgate, blisters on the lower front doors and smelled funny (burning coolant + missing on start up - suspect HG) for £1650! It was a mulberry highline and I can only assume he needed to recoup the money for the cost of the chain repair. My 95 Mk3 -
He did mean chains, some idle issues and headgaskets. I know working at a dealer you always see the worst and get put off! My dilemma was to either get a 16v or Vr and after reading the TSR's page I had to confirm it! To tell the truth I'm still in two minds, depends what decent car comes up first. Was funny today, my friend is convincing me to get a Honda VTi and took me to a meet in South Mimms, he said something will catch my eye and I'll convert. Saw a black Mk3 on BBS splits parked between all the jap crap I took it as a sign -
A pull and a knock, maybe a bit more
Leon R replied to Special K 81's topic in Wheels, Brakes, Suspension and Steering
Got the same loud knock problem on my Mk3 GL. I've changed a gearbox mount a year ago, NSF lower ball joint which was split, both top mounts which had play and both wishbone bushes that were split and still have this problem. I was told that the wheel bearing is tilting in the hub by a VAG tech, feels a lot more like its the NSF. A quick test was to reverse full lock on an incline and see how loud it is then as opposed to a flat road. I checked the wheels for play, checked all the engine mounts, thought it was a driveshaft/CV problem too. At the moment the Wheel bearing is the cheapest thing -
Thanks for your responses! Thats good to know. Im assuming they are recommending the additional inspection to cover themselves, no one would be happy doing the conversion to find out a year later the engine's had it. Spoke to a VAG tech to also confirm, said I should be worrying about the "other" problems! :-# Thanks again! -
Hi, I joined this forum ages ago when I first wanted a Vr unfortunately being on an apprentice wage meant it had to wait until now. So Im all geared up, 2K waiting and whilst doing a bit of research I found on TSR's website that higher mileage (120k on) suffer from bore wear? http://www.tsr-performance.com/pages/transplant.asp Seeing as my budget restricts me to this mileage band, i'm wondering if any of you guys have experienced this and had to do rebores/rings? I did a bit of a search but couldn't find an answer, hopefully thats a good sign... Right?! Leon
