Andrew_Cooper
Everything posted by Andrew_Cooper
  1. Thanks I have a 1997 Mystic Blue 3dr. The rust is worst on the rear quarters at the bottom of the arch underneath the window. Also got an unusual area of rust forming under the passenger side rear light cluster where there is a vertical indent running down to the bumper. Someone had a look at it and said plating would be required for a permanent fix. Thanks for the advice on the scrappy, know any good ones in the area? Also, will the wing need to be from a VR6 or can you use any other models? I imagine the wheel arches are differently speced.
  2. Got some body rust issues that need sorting including a passenger side wing that needs replacing. Has anyone got any suggestions for a trusted bodyworker they would reccommend in the Leeds/Harrogate area. Also, what should I expect to pay for a new wing, plus plate repair work to both rear arches which will require removal of the under door trims. I've been quoted £800 exc VAT which seems reasonable to me but don't want it to be too cheap, if you know what I mean.
