deanjames
About deanjames
milton keynes
Hi I am looking into tucking my vr6 engine bay. Getting rid of wires and relocating waster bottle ect. Any tips please or can someone point me in the right direction Here is a picture of how it currently is!
Anyone have any info on this just looking at hiding some wiring and making the bay look a bit cleaner on my VR6
I need to replace my fuel hose going into the fuel rail the upper one. Can anyone recommend any decent hose for my to replace this with. Or where i can get originals. Anyone know the diameter
Ive looked at the top one looks like its seem better days. With the leak it dont leak all the time any reason for this ?
Hi finally found out where my fuel leak is coming from. Left side of the chassis leg where they disappear into the car. Heres a quick vid any idea what it could be.
Hi Guys all help appreciated. I have a fuel leak on my corrado vr6. Its a strange one its leaks intermittently, ive followed the fuel lines as far back as i can and where its leaks from its disappears into the body of the car. When it leaks, i turn the car of and then start it again and it stops, so thinking it is pressure related and maybe a line going back to the tank? Here is a picture of the area. Its drivers side. Many thanks
Car Cutting out - Factory immobilizer ?
deanjames replied to deanjames's topic in I.C.E, Security an Electrical
I'm sure it reappears but il clear the weekend and see what happens thank for your help -
Sorry that's just and example of what it seems Like it's doing, united motorsport why do you think factory immob causing the issue that's my Bet -
The third time I am putting my foot on the throttle and it's fine, so my guess is that the factory immob is kicking in blocking the fuel pump and starter ect. I thought about it a lot and it has to Be the ecu immob playing up. I don't want to spent money and just go ahead and deimmobalise the ecu without it being looked at. But I can't think what else it can be. Thank you united motorsport for your reply -
Hi Guys, Hope you can help with this really frustrating issue i am having and i am almost 70% sure its the factory immobalizer now I have done the following - Cleaned ISV - New fuel filter - New Blue temp sensor - New battery cleaned ignition coil I have recently had a new alarm fitted, reason this was fitted because i thought it was an issue with the alarm. - Car was doing this before i had a new alarm fitted. - Fitted a new one hoping it was at fault and the car is still doing it. The issue is i got to start my car and its cuts out. The engine goes to crank and then nothing. I will try afte
Brake pads catching wheel!!
deanjames replied to rossvr6's topic in Wheels, Brakes, Suspension and Steering
having the same problems with my wheels message me buddy need to chat
