leigh_f
About leigh_f
ramsgate, kent
rear light wiring colours for towbar
leigh_f replied to leigh_f's topic in I.C.E, Security an Electrical
if you could that would be greatly appreciated -
never thought to search internet!! thanks but just trying the lazy way other than multi meter to check which wire supplies which. done plenty of towbars just can't find any info on mk3 wire colours. -
Hi does anyone have the colours code for rear light wring as am about to fit towbar! it is a necessity for the jetski
yep got seals sorted thanks now just got to figure out how to do it all? any tips much appreciated!
Hi i have a small gearbox oil leak which i believe is coming from the seals does anyone know if and where i can get replacement seals? thanks
no spark to plug or lead cylinder 2
leigh_f replied to leigh_f's topic in Engine Maintenance and Problems
thanks guys just trying to get a new pack without paying silly money! -
if it was plug would i still get arch from lead? if not i will swap plug around thanks -
thanks for suggesting it though -
done that same cylinder missing. leads are fresh out of pack an hour ago! -
hi my vr6 golf obd2 has developed a fault. upon closer inspection i found that there is no spark to cylinder 2, changed leads and still nothing. the lead isn;t even arching so problem is before lead. i have repaired coil pack in the past with the jb weld method and can;t see any cracking. is there anything else to consider or test before shelling out for a brand new coil pack?? thanks
as i'm snowed in i thought i'd design a new sub arrangement. however i don;t currently have my car with me and need some dimensions, can anyone help [without getting cold and wet!]? i want to know the floor plan of the boot, [narrow part, wide parts depth and what depth it goes narrow to wide] and the depth and width of the spare wheel or wheel well. might keep me occupied for a while! thanks
cheers will look into getting these bits sorted to at least rule tham out, if i can find someone to do the work!
did you ever get to the bottom of this? i have a similar problem. also where did you get box servied calico? thanks
been searching on here and have only come across brief explanations but is it easy to do with engine in? where could i find a guide as no haynes exist many thanks
addition to saga, got in car yesterday and all works fine, no sign of problem window moves up and down quickly without hassle. could this rule out motor?
