Big Dub
Everything posted by Big Dub
  1. Has anyone had this problem. The intermittent & normal wipers work when they feel like it the only one that works properly is the fast wipe. When I first got the car the intermittent and fast wipe worked then a few months later the intermittent started to freeze after doing about 3 wipes of the screen. Now i'm only left with the fast wipe working properly. Does anyone know how to rectify this problem as it is beginning to get on my nerves. Thanks gals & guys :@
  2. Sorry forgot to tell you the price $13.95 each, if you need 12 that would be $164.40 +p&p.
  3. I have just replaced all my tappets, valves, springs & cylinder head. I got my tappets from the states & it was cheaper than buying a set from GSF, VAG or Eurocarparts. My engine sounds so sweeeet now. Make sure when you put the cams back that the slots in the ends of the cams are perfectly horizontal with the surface of the head in that you should be able to insert a flat metal plate to keep the cams still. Good Luck
