contorted fungus
About contorted fungus
richmond north yorkshire
i've got 167008 on the odometer and it runs like a swiss watch always look to replace induction tubes and the non return valve for the cam breather on obd2 cars as they are prone to leaks and make them run rough
good old abs (common aint it)
contorted fungus replied to contorted fungus's topic in Wheels, Brakes, Suspension and Steering
managed to get hold of one although strangely it came off an early mk4 but it works -
they both had the same numbers apart from the last letter however i took it to the dealership and it should have a unit with 3A0907375A on it and my two end with 379 both for sale if anyone needs one -
how come it won't work with an ebay lead -
sister in law lives there was dropping off my daughter coz she stayed there for a fortnight due to school holidays
where can i get a full version of vag com and a usb lead to connect to my laptop -
can you recode the abs unit with other diagnostic equipment -
not long back from leicester i ended the 320 mile round trip with a figure of 40.7 on 95ron fuel but i have seen 47.6 on optimax obd2 owners should check the non return valve for the cam breather as it makes a big difference to fuel economy (when was the last time you changed it)
anybody near scotch corner with vag.com? -
Pads & discs + new tyres
contorted fungus replied to kcw's topic in Wheels, Brakes, Suspension and Steering
i found t1r's to roll away at the edges too quickly aint tried the paradas running falken ze912's at the mo nice and grippy -
yeah i've put that back on its not caused by the new abs unit is it? does the master cylinder have a slide valve in it that needs resetting -
been using a brand new bosch diagnostic tool the local garage owes my dad a few hundred favours from his welding -
i've bled through 1.5 litres of fluid as it made sense to change the old fluid at the time and how the hell do you recode it -
anyone else apart from me and highline vr6 go to this one
right here we go. got a 97 vr6 with an abs fault it reads as hydraulic pump not in parameters have changed pump unit for a known good complete unit but it has a different letter at the end of the part number now the bloody thing keeps the handbrake light permanently on. (argh its making my head hurt) is there a relay for firing the unit that i need to change coz i couldn't find any control boxes under the dash (its all apart at the mo) does anyone near me have vag.com to help fix/clear fault codes help please i miss driving it ;(
