hi all im new here just spotted post i have a 95 vr6 and had the same problem a few years back after lots of fiddleing a bloke at a vw dealer advised me on a fix there is a control box located behind the dash drivers site next to the spoiler switch it is where the transponder coil is fed to there sometimes are loose connections in it and sometimes dry solder joints to the circuit board i took mine out it is in a box that you can undo and check the connections and if you have the know how you can give the solder to the circit board a flow with an iron im a qualified electrical service engine
