gaz2180
About gaz2180
    Edinburgh
  1. Thanks guys - will check tonight while changing a fog light bulb. Ta
  2. Hi guys, Hope you can help. My MFA cycles through the usual info but misses out the last symbol which I believe is the ambient air temperature. Is this right? If so, is it missing this out because it was an optional extra? Or only available on Highlines? Can I assume that there will be an unused wiring loom in the bonnet somewhere which I could connect the correct sensor to for this to work? Thanks
  3. That's my problem - the simplest answers never occur to me!
  4. Hi all, Bought an induction kit from fleabay and it didn't come with a fitting kit. Ideally I need a strip of metal with holes in it to give me some flexible fitting options. For the premium members, look at the BMC fitting guide in the Knowledge Vault and you'll see a pic of exactly the thing I need. Anyone know where I can get this or have something spare lying around? Ta
  5. Evening all, Need to replace my water pipe. Looking to replace with OEM part which I believe is part number 021 121 085 from VW. But as I need to walk and the Ford stealer is much closer, does anyone know the Ford part number? And rough cost? Ta
  6. Evening all, Last week I noticed my coolant level was low so topped it up a bit. At the same time I checked the oil and there was a thin layer of 'mayo' on the cap. I wiped this off and thought nothing of it as I normally only run short journeys on the car and think this is pretty common. Anyhoo at the weekend I drove to Birmingham and back (from Edinburgh) and my coolant level light came on about 3 times so I was losing cooland rapidly. I also checked the oil cap when I got back and there was mayo galore all over it. Weirdly the water temp and the oil temps both stayed normal for the entire
