Damien.
About Damien.
Haverfordwest, Wales.
How much on average will the Throttle body cost and the re-map ?
do you think those parts are worth the 20BHP ?
Is it possible, and what parts are need, how easy is it etc ?
I have the metal tool. Maybe my leads are a faulty set ?
Recently my car has been experiancing some miss firing. Ive replaced the plug, the leads and the coil pack, but the problem still existed. I checked the car in the dark last night and noticed small sparks where the lead joins onto the plug itself. Now im using a lead removal tool, so what could be causing this ?
Ive just recently bought a removal tool. They are brilliant and a much needed peice of kit for removing leads without breaking them. Quick question on my behalf. How do you know when youve tighened the plugs enough after fitting new ones ?
What is this, and has anyone got one ?
Damien. replied to Damien.'s topic in Engine Maintenance and Problems
So its not really needed ? -
I need this part, as i snapped mine whilst taking off the throttle body. Whats it called and has anyone got one ?
I bled my clutch system, and it was great for about 2 days. Then the problem just came back. Everytime i get into the car i either gotta do what you have to, or pump the clutch for it to start engaging. I havent got a clue whats causing it.
Im looking at replacing the standard speakers in my VR6. So how big are the standard door speakers, and the rear quater speakers ? Thanks.
Would large holes in the exhaust cause the car to have running problems ? I reversed into a rock the other day which ruined by back box. It fell to peices because it was so rusty and i havent had the chance to replace it yet.
I went to the gym tonight and the cars slight miss fire type problem had gotten 100 times worse. So when i got home i decided to take the spot light and check arround the engine bay. Here is what i found, do you think this would cause a problem with the running of the car ?! [mod edit resize pics] Moderator edit by: cadguy
Well my cars developed a bad missfire do to a faulty lead. Im going to replace my origional leads with some nice shiney magnecor ones. But which ones should i get ? 7mm Black 8mm Blue 8.5mm Red Thanks in advance !
