P262YUD
Everything posted by P262YUD
  1. Hi, does anybody know where to buy a new maf meter for my 97 golf vr6. after discovering that my throttle body was completely covered in oil from the crankcase breather i thought it would be a good idea to clean the rest of the system including the maf, i now wish i had'nt bothered!! ive managed to snap the small chip in the maf making the car run bad and use even more fuel!. ive had one price from euro and they quoted me £180, but that may have been for the earlier vrs, anybody got any ideas?
  2. P262YUD
    exhaust
    HI THERE, I NEED TO KNOW THE SAME ANSWER! MY STANDARD EXHAUST AND CAT HAVE GIVEN IN! iVE SEEN AN STANDARD EXHAUST ON EBAY FOR THE GTI, AND IM SURE THERE THE SAME. ANY BODY KNOW FOR DEF. CHEERS
  3. Does that mean that they will not fit? Are there any adaptors that i could buy.
  4. hi there, they're going onto my golf vr6 97
  5. Hey guys, can anybody help? I've jusy bought a set of 17' audi a4 tdi alloys, there off a 2004 model. just tried to fit them and they don't line up with the stud holes!! any ideas?
  6. hi, Anybody know where i can get hold of a crankcase breather for my 97 golf vr6. It's the small diapham unit which is to the left as you look directly down at the engine. My local vw dealer want £100 just for a new one. any ideas
  7. Hi thanks for your reply- the problem doesn't clear when it's warmed up and yesterday I had a look to see if any of the leads were loose and got an electric shock from the coil pack area while the car was running! I checked for splits and things but all seems fine...
  8. A month or so ago, my golf had a full service which included new coil pack, leads and plugs all round. The car also had a new air filter and the idle control valve was cleaned too. The car was running fine until we had all that rain recently and i was forced to go through a small flood!!!..at low speed. Since then the car has a low down splutter, or flat spot at around 1,200 rpm which wont clear!! any ideas?
  9. Thanks for that. The garage that carried out the work for me said there was no adjustment on mine, but there has been on other golf's that they had lowered in the past. Mines on a p plate, any late changes to the suspension set up?
  10. After having my Golf VR6 lowered i have encountered problems with the camber, the front wheels are now sticking outwards slightly at the bottom, enough to make the car skittish. Have tried tracking, different suspension caps and am now running out of ideas. I am pretty sure that my front standard shockers are tired. Anybody out there?.....
  11. Thanks for that, will have all bushs checked out. would new standard shocks help??
  12. Hi, I have recently had my golf vr6 lowererd using the Eibach lowering springs. The drop was by 30-40mm. The front end does not seem to have dropped and the camber of the wheels point inward at the bottom, making the car skittish. i've tried having the tracking done, but no difference. Any ideas?
