NEILX5
Everything posted by NEILX5
I have put some mk4 style headlight on my mk3 vr6. They work, but i get huge beams of light out from the side and above. Anyone else had this problem? Cheers N
Hey guys, just a quickie that i thought i would never come across. Is this a common problem? I have a standard mk3 Golf Vr6 with an uprated Milltek exhaust, and now that im lowering on coilovers it seems to be sandwiching itself between the underneath of the car and the axle. The car is low, but would like to go more, but as its knocking already will it go from bad to worse? Cheers.
Camber adjustment on lowriders, how do u do it?
NEILX5 replied to NEILX5's topic in Wheels, Brakes, Suspension and Steering
Thanks, if you could get those pics to me that would be great. Thanks again!!! -
Hi Guys, ED38 show last weekend was a great turn out, and all the cars there as ever, were top class!! I have a question for all you low riders out there, my mK3 is on coilovers, and when i come to slam it, the camber is put out and wears down the tyres. But how come no garage, can adjust the camber on REALLY low cars. There must be a way, any ideas? Cheers N
Hi Guys, just wondered if anyone has heard of a good paint sprayers, within the Milton Keynes area. My rear arch is starting to rust and needs attention b4 it gets any worse. Hope you can help N
Hi guys, again!! My car has been pulling to the left for about a year and no garage has a clue, and it driving me insane. Went into another garage today, and they swapped the rear tyres to the front and the front to the back, and got worse to the point it was pulling the steering wheel. Swapped back again and got better, but still pulls.....what the hell is going on? The camber and tracking is spot on aswell. Please help Neil
Going through tyres quick!!
He did it for me as a favour on a Sunday, so I dont really have any come back with no reciept. The whole lot was done for £80. -
Camber was set at Kwik Fit when they fitted the suspension -
The wear is on the inside of the tyres, totally bald -
Hi Guys. Have gone through a front pair of tyres in less than 6 months. Had the tracking & camber done b4 tyres, but still drifts to the left v badly. The car is v low on fk coilovers and I just wondered if the lowness is the prob, and if so what can be done to enjoy a low car without going through tyres. Hope you can help Neil
Hi guys!! I’m getting a loud humming noise in the car I think it may be a wheel bearing (what else could it be?) How can I tell which one has gone? Is there an signs? And finally is it a job for a garage or can I do it as my garage charged £80. +vat which I think is steep. Hope you can help Neil
Hi Guys Ive been told that on my '97 vr6 there is an anti-thrash sensor to stop it being reved when it is cold. As I start it when cold and rev it it will not reach 6000rpm but come down and get all chuggy until warm. Have you heard of such a thing? Neil
Hi. Does anyone know for sure how low you can go on KONI coilovers? Neil
Hi Guys, I thought aftermarket exhausts should be the same bore diameter as the manufacturer? I was thinking about getting a Milltek but the bore is smaller, now im swaying to a Jetex as the bore is the same 2.5inch. How important is this? Cheers Neil
Hi again Guys! Sorry to keep asking all these questions but am new to all this exhaust talk. Need a new exhaust and cat but the high flow cats are almost £300 but decat pipes are only £80, is there a great deal of difference between them. Also changing the cat over once a year how hard is this do do yourself at home? Cheers again! Neil
Hi guys, what coilovers do you recommend? I am after some coilovers that are fully adjustable, ride and height, but will also lower the car a long way. Some coilovers go to 70mm but im sure they drop more than that. Cheers Neil
Hi Guys, exhaust shopping is doind my head in!! which one should I get, because obviously I want the best for power gains. An does anyone recommend Magnex, they come standard on the Astons but does that mean they are could? Hope someone can help me end this quest. Cheers Neil
Pleeeeease help, I own a 97 VR6 and lately the interior creak is out of control it sounds as if every panel is creaking and i dont know where to start. The car has after market suspension braces underneath ( could that be it?), But why is it all of a sudden its so bad? Has anyone else suffered this dreadful creaking? Hope you can help Neil
Just a quickie guys. Need a new exhaust and just wondered what the best performance wise I should go for? Thanks N
Hi guys my drive chains on my vr6 need changing and i might aswell get my clutch done while it is off. Do you know anyone who can do this without bankrupting me? Im also Miltom Keynes based if that helps Thanks Neil
Hi guys Im losing coolant but yet not over heating! Pressure is building up and bursting out the top of the cap and also leaking from somewhere onto the gearbox, the fan cuts in at the right time. Ive been warned this could be a gasket leak, but surely if that was true the car would run bad all the time, but doesn't. Hope you can help Thanks Neil
Cheers mate! How used is it and where are u based?
Does anyone know a resonable place to buy a new cat for a mkIII golf vr6, without ending up bankrupt? Cheers Neil
Hi there, Just wondered when the cambelt should be changed on my MKIII VR6? My service book says 60k for TDI & SDI only, and VW said the VR6 normally gets changed at 100k. Is this true if so why is that (does it have a tougher belt?) Thanks Neil
