A2T
Everything posted by A2T
  1. Before ordering, READ the caveat at the end of this thread! From the designer of the bulletproof metal VR6 coolant pipe and metal radiator neck?. Good news for Volkswagen MkIV VR6 owners!! I have designed and manufactured replacement intake manifold shift rod bushings to replace the faulty OEM bushings. Part #10 in this pic Failure of the OEM bushings are very common, and indicated by a rattling noise around 4000 rpm as the rod is changing over ? many think it?s the hydraulic lifters making the noise when in fact it is the plastic variable intake manifold shift rod bushings. VW will be ha
  2. Just curious... Check http://www.vr6oc.com/forum_viewtopic.php?27.37797 id you do.
