h3lter 0 Posted July 17, 2006 Report Share Posted July 17, 2006 hi, i have a problem with spark plugs and need to check gap with feeler gage, any one know the correct distance? thanksH3 Link to post Share on other sites
badboyV6 4 Posted July 17, 2006 Report Share Posted July 17, 2006 should be in the Bentley manual pm me if you havent got and ill check tonight Link to post Share on other sites
badboyV6 4 Posted July 17, 2006 Report Share Posted July 17, 2006 spark plugs are pregapped so as long as the part number is correct then youll have no issue. Double check part numbers as well mate... :-) Link to post Share on other sites
delete-me 1 Posted July 17, 2006 Report Share Posted July 17, 2006 hi' date=' i have a problem with spark plugs and need to check gap with feeler gage, any one know the correct distance? thanksH3[/quote']If you buy NGK BKR5EKU or NGK BKU5EKU-Platina, they are pregapped from the factory. Have been reading a big post about it on Vortex. It ended up with, that they contacted the NGK factory. NGK said that both the spark plugs are a perfekt gapped match to a "stock" VR6 engine. Ive been using both, and they are working perfect for me the last 6 years. Platinum are abit waste off money though.. Regular BKR5EKU are half the price, and you can afford to change them more often. ( Link to post Share on other sites
