Guest VRSIXY Posted March 20, 2006 Report Share Posted March 20, 2006 Hope you can help me....I've recently bought a VR6 that was running like a dream then i started to notice a slight flat spot on ecceleration and then a little juddery on idle, then yesterday i started it up and there was this awful juddering coming from the engine and when i put my foot down to move it sounded like a tractor. I took it for a ride and it cleared for a short while and then started up again. I also find when i put my foot down the car just doesn't seem to go anywhere, jerks and sounds terrible. ( It had new spark plugs about 5 weeks ago. Link to post Share on other sites
Guest VRSIXY Posted March 20, 2006 Report Share Posted March 20, 2006 Forgot to say there is a strong smell of fuel also. Cheers. Link to post Share on other sites
jsh712p 0 Posted March 20, 2006 Report Share Posted March 20, 2006 It could be something simple like a damaged plug lead. Who fitted the replacement plugs and did they use the correct tool to remove the plug leads? - they are easily damaged. Failing that - you really need to get it plugged into some diagnostics - something like VagCom on a laptop would be ideal - Link to post Share on other sites
Guest VRSIXY Posted March 20, 2006 Report Share Posted March 20, 2006 The plugs were fitted by The Phirm so i imagine they used the correct tool, i've also checked the service history and it had a new coil in the middle of 2005 so i'm hoping it's just going to be he leads. Link to post Share on other sites
mk3anni 0 Posted March 21, 2006 Report Share Posted March 21, 2006 Give tim a call @ the phirm, he might be able to answer your question......these cars are ever so sensitive to HT leads though, so if there dying it might be why you have the problem you do. Link to post Share on other sites
dubloke 4 Posted March 22, 2006 Report Share Posted March 22, 2006 sounds like a lead breakdown to me tbh. like steve said, tho he's on commision by the phirm, get back in touch and i'm sure it'll be easily sorted! Link to post Share on other sites
