Will these wheels fit my mk3 golf vr6?
Hi
I've seen some nice wheels for sale. They look good but will they fit my golf mk3 vr6? They are 15" split rims but I want to continue using 205 tyre width. Is their width of 6" too small? By the way I know very little about ET offsets and actual alloy width. From what I know I think the alloy width on a standard 15" bbs vr6 alloy is 7.5" (is this correct or are they 6.5"?)... not sure what the et offset is though. If I go up to 16" on alloys (still with a 205 tyre width) what offset and alloy width would I need... and same if I go for 17" alloys?
Here is the alloy name and size:
VW GOLF `BBS RS796 ` ALLOY WHEELS 6X15 98-05
SIZE IS 6 X 15 ET38 5 X 100
Thanks for any help.
Standard 15's are 6.5 wide IIRC. I think a 205 is a bit wide for a 6" rim - 195 should be ok.
Rim width is up to you really, but a 7 or 7.5 is easiest for avoiding scrubbage. ET around the 38 mark with the above width keeps things tidy. The offset and width would not change with a larger diameter, though of course you would need to reduce the profile of the tyre - ie with 205's you'd want a 205/45 on 16's and a 205/40 on 17's.
