So im rebuilding my 2.8 vr and thought it best to give the pump the once over as you do. All the tolerances check out and its not to badly scored up but when i took it apart the gears fell out and there is 2 arrows that kinda look like timing marks but im not sure, i had a look in the bentley book but it doesn't say anything about it.
Any one got any ideas?
It still turns fine so i don't think the gears are off center or anything but i what to be sure it goes back together correctly.
 3FE35291-623F-46B3-8264-F69D71B8E60A_zps
I also found this in the pick up gauze which was quite alarming but im pretty sure the bits are from the destroyed timing chain guides i replaced a while ago
70137ADD-CE40-4C56-8B34-FAED5705273B_zps
  • 4 weeks later...
