B-Man 16 Posted January 5, 2014 Report Share Posted January 5, 2014 Hi. So after installing a Turbo and having the battery relocated to the boot I am loosing my dash guages when the car is running which I think is a earth issue from relocation. As im now fed up im going to put everything back up front but need to use a battery as small as possible to fit upfront with all the Turbo pipes etc but powerfull enough. Racing battery as sold by DeamonTweaks... Sent from my iPhone using Tapatalk Link to post Share on other sites
GordonC 20 Posted January 6, 2014 Report Share Posted January 6, 2014 Did you use a thick enough wire and a good junction box up front mate as I've relocated batterys in 2 of my cars and never had any problems. I just went to the scrapyard and found a bmw and took the whole battery wire and junction box out and it works spot on. The wire is really thick about 13mm so there is no power loss Link to post Share on other sites
GordonC 20 Posted January 6, 2014 Report Share Posted January 6, 2014 And it only cost about £5 for the lot Link to post Share on other sites
B-Man 16 Posted January 6, 2014 Author Report Share Posted January 6, 2014 Did you use a thick enough wire and a good junction box up front mate as I've relocated batterys in 2 of my cars and never had any problems. I just went to the scrapyard and found a bmw and took the whole battery wire and junction box out and it works spot on. The wire is really thick about 13mm so there is no power loss Well i had it done...but not sure on the junction box if honest,dont look that great. Ill take a pic later of it. I bought BMW cable anyway and that is being used. Only the pos though. Sent from my iPhone using Tapatalk Link to post Share on other sites
GordonC 20 Posted January 6, 2014 Report Share Posted January 6, 2014 Yeah you only need the bmw wire for the pos but it does need a decent junction box up front to connect it all otherwise you will lose current there. How is your neg connection is it bolted down good enough to the boot floor or that ? Link to post Share on other sites
B-Man 16 Posted January 6, 2014 Author Report Share Posted January 6, 2014 Gordon...any reccomendations fo a block apart from the BMW one? Have u maybe got a pic? Also where did u mount the earth from the battery in the boot? Sent from my iPhone using Tapatalk Link to post Share on other sites
Lukey. 381 Posted January 6, 2014 Report Share Posted January 6, 2014 I would say seatbelt mount point would be the best place, with batts you need about 500cca for the vr6 engine Link to post Share on other sites
B-Man 16 Posted January 6, 2014 Author Report Share Posted January 6, 2014 Ive got something like this up front... Sent from my iPhone using Tapatalk Link to post Share on other sites
B-Man 16 Posted January 6, 2014 Author Report Share Posted January 6, 2014 So I just checked where the earth frol battery was located and he ran it to the body just infront of the back seats...so I took it off and mounted it to where it is now in the pic to see if that will make a difference but it doesnt... Will the lenght of the negative cable affect it as it is a bit long... At the back... Block at front... Sent from my iPhone using Tapatalk Link to post Share on other sites
B-Man 16 Posted January 7, 2014 Author Report Share Posted January 7, 2014 That Junction box o.k? Sent from my iPhone using Tapatalk Link to post Share on other sites
