I've ordered the tensioner kit from febi for my 98 vr6 obd2 as its done 158k and is starting to rattle so I started the strip down today, expecting to see some pretty major wear and all I found on the upper is this.......
Posted Image
Is it possible the chain is also stretched and adding to the rattle?
Thanks Stew
sent using telepathy
  • 3 months later...
Change the lot :))
Chains stretch over time(depending on servicing and oil quality that time can be less or more) this leads to tensioners being at the limit of there travel and/or the tensioners age and don't hold suffice oil pressure to keep the chain under tension. Both will lead to the chain slapping about and damaging the guides. Not normally the guides themselves that started the noise :)
