I'm toying with the idea of changing the final drive in my standard vr6 gearbox, doesn't need a rebuild or anything. All the gears are good just bin reading a lot lately about changing the final drive ratio can transform the whole vr engine. From what I've read 3.68 Final Drive seems the best choice maybe going up towards 3.8. I believe the G60 box has a 3.68 final drive gear as standard but two questions really. Are there any more common vw 02A or 020 gearboxes that make use of that or similar ratio as I believe both fit into a vr6 02A box?
Please correct me if I'm wrong as the more I read up about this the more I'm learning. I'm no experienced mechanic :) also can the final drive be replaced with the gearbox insitu or does it need removing from the car?
Apologies if the second question is a blatently obvious one!
