Udi Siag 0 Posted January 15, 2012 Report Share Posted January 15, 2012 RPM goes up (ONLY) when i turn the lights on and if i'am standing in a traffic light with a turn signal on. it's go up from 680 RPM witch is idle to 1000 RPM (not stable) , sometimes more when the fans in ON.i connected a Battery Booster and the RPM didn't move or act crazy even i turn everything ON it stay stable, So i think i need more amperes so maybe the dynamo or the battery.*replaced a new dynamo *replaced a new battery and it's still the same what else should i do ?i will be happy if someone knows anything about this problem. Link to post Share on other sites
rodney 17 Posted January 15, 2012 Report Share Posted January 15, 2012 Does this happy only when the engine is only hot or cold?... or all the time??? Link to post Share on other sites
Udi Siag 0 Posted January 16, 2012 Author Report Share Posted January 16, 2012 Does this happy only when the engine is only hot or cold?... or all the time???Exactly . it happen only when the engine is hot. Link to post Share on other sites
Udi Siag 0 Posted February 19, 2012 Author Report Share Posted February 19, 2012 the problem was solvedOn the battery (+) there's a red wire that goes to the inside car next to the fios box. it was thin, i added a thick wire to it and it's all good now.thanks Link to post Share on other sites
