Guest v6fred Posted March 9, 2005 Report Share Posted March 9, 2005 hi,any common causes for this ?? cant see obvious leaks, could it just be the cold weather / snow outside ? (and car not garaged)thanks! Link to post Share on other sites
stu h 0 Posted March 9, 2005 Report Share Posted March 9, 2005 do you have aftermarket rear lights fitted? quite often they let in water Link to post Share on other sites
dubloke 4 Posted March 9, 2005 Report Share Posted March 9, 2005 sometimes if you dont do the lights back up properly, they are only small nuts so peeps tend to be gentle with them, they can let in water as stu has said. it could have had aftermarket lights on and removed, or if you have some on now! it can also leak in thru the rear screen on some, more so if its had a new/sh hatch due to rust, or some paintwork, as the window is bonded in and unless its done properly, will never seal tightly enuff again! Link to post Share on other sites
Guest v6fred Posted March 9, 2005 Report Share Posted March 9, 2005 Cheers for replies guys, seen similar with the lights, so will check em out. Link to post Share on other sites
