Jonny_1983 0 Posted July 16, 2011 Report Share Posted July 16, 2011 Hi guys,After doing a bit of cleaning under the bonnet i found that it is a bit difficuilt to get the car into 1st and 5th gear at times. I never touched any thing underthere, just a quick degrease and polish of paint and stuff.Cheers for any help. Link to post Share on other sites
Jonny_1983 0 Posted July 17, 2011 Author Report Share Posted July 17, 2011 went out to the car this morning to have a look at the car.The only thing i noticed was that even though the 13mm bolt that connects the linkage to the box is tight but there is still movement in the bit it tightens up onto. you can move this bit up and down and angle it. If you look at the bolt there is a bout a 2mm gap between its base and the base of the linkage. Link to post Share on other sites
