Have you unhooked the handbrake cable before anything else. it could be down to cable so before i suggest ways to free it up, take the handbrake cable off and see if the lever springs back.
if it does it's the cable, if not the calipes.
if both are ok and it's not caused by handbrake it could be a few things such as seized piston, seized caliper sliders, or maybe down to a collapsed flexy acting as a 1 way valve almost. you'd tell this by trying to push piston in as it is and if it doesn't go back, open the bleed nipple and try again.
if it goes back it's more than likely flexy, if it still doesn't it's seized caliper.
hope this helps.
