Car Cutting out - Factory immobilizer ?
Hi Guys,
Hope you can help with this really frustrating issue i am having and i am almost 70% sure its the factory immobalizer now
I have done the following
- Cleaned ISV
- New fuel filter
- New Blue temp sensor
- New battery
cleaned ignition coil
I have recently had a new alarm fitted, reason this was fitted because i thought it was an issue with the alarm.
- Car was doing this before i had a new alarm fitted.
- Fitted a new one hoping it was at fault and the car is still doing it.
The issue is i got to start my car and its cuts out. The engine goes to crank and then nothing. I will try after a few attempts and then it will fire up like nothings happened.
Its 50/50 i could get into my car one morning and start it up and it starts fine first turn of the key and others it takes around 4-5 attempts.
I have put the car on VAGcom and get the following code.
Controller 021 906 258 co
Coding: PMC 1HS
17978- Engine start blocked by immobiliser
P1570-35-10 Intermittent
When it cuts out i put the key into position one and it chirps so this leads me to believe its immobilisers related.
When it starts it starts fine put key into position 1 and no chirps.
Any ideas guys, or anyone i could take it to I am located in Milton Keynes
Any other issues you guys had like this i am thinking of de immobilizing ECU,
When it starts it runs absolutelySkrU0tKz_xI[ fine
Many thanks
The 1st 2 times look and sound like the factory immobilizer in the ECU.
The fact that the fault code appears in the ECU is pretty conclusive.
I would guess at you have a intermittent fault somewhere along the line.
If you have an after market alarm/immobilizer, having the factory one removed from the ECU wont cause any security issues.
The third time I am putting my foot on the throttle and it's fine, so my guess is that the factory immob is kicking in blocking the fuel pump and starter ect.
I thought about it a lot and it has to
Be the ecu immob playing up.
I don't want to spent money and just go ahead and deimmobalise the ecu without it being looked at. But I can't think what else it can be.
Thank you united motorsport for your reply
