VRRob 0 Posted April 18, 2011 Report Share Posted April 18, 2011 Hi guys i have a slight missfire at low revs and when i let off the accelerator in gear down hills for exmaple i can hear the exhaust popping... i plugged it into vag-com but no faults where found. Anyone have any ideas? Link to post Share on other sites
russj249 2 Posted April 18, 2011 Report Share Posted April 18, 2011 You might need to check if it's a miss or an air leak or something.most common things to check on these are coil pack, they are common to crack and arc to head. leads don't sit on plugs properly and you can see a spark looking down the spark plug holes at night. also check plugs as it doesn't take long.if all of these you can confirm are good, then maybe try a compression test.as for popping mine does the same. had a few friends follow and say it flames on gear change, and pops all the time, but again no faults stored and doesn't use excessive fuel. Link to post Share on other sites
VRRob 0 Posted April 19, 2011 Author Report Share Posted April 19, 2011 Ok I will look into all that and see how it goes. Thanks for the reply. Link to post Share on other sites
Sarge-Devil 0 Posted April 19, 2011 Report Share Posted April 19, 2011 i have the same problemMine now runs on 5 cylinders ..even changed the coil pack...and leads..engine may have a fault.Hope it doesnt Link to post Share on other sites
Vw_owner 1 Posted April 19, 2011 Report Share Posted April 19, 2011 Hi guys i have a slight missfire at low revs and when i let off the accelerator in gear down hills for exmaple i can hear the exhaust popping... i plugged it into vag-com but no faults where found. Anyone have any ideas?i have the same thing, expect i dont have a miss fire,im prety sure its down to the exhaust system, my corrado has a flippin 4" drain pipe back box from the previous owner and im certain this is why !! i used to own a mk4 golf that did this after i had fitted a scorpion catback and before that it was very quiet and would never pop n crackle, something to do with back pressure? Link to post Share on other sites
VR6Gill 1 Posted April 20, 2011 Report Share Posted April 20, 2011 Could it be a broken crank case breather? Link to post Share on other sites
russj249 2 Posted April 20, 2011 Report Share Posted April 20, 2011 It could be. that way it'd be sucking air after the air flow meter so will put readings out. don't think it'd make a massive difference if it's just split a bit though. Link to post Share on other sites
VR6Gill 1 Posted April 21, 2011 Report Share Posted April 21, 2011 It could be. that way it'd be sucking air after the air flow meter so will put readings out. don't think it'd make a massive difference if it's just split a bit though.It made a massive difference on mine. Just hold it tight as ur engine is running and see if it makes a difference. Link to post Share on other sites
