GingerTI 0 Posted March 5, 2011 Report Share Posted March 5, 2011 well i bought this vr6 obd2 about 2 weeks ago and all was good until coming home the other night, when a loss of power came and a large rattling noise appeared.started stripping down to find this:can only imagine its been off at some point and never tightened up properly?i don't no the excess of the damage yet to find out i need a sprocket as this one is dead. after that's on i can do a compression test.can somebody tell me if the sprocket pictured is the intermediate sprocket or the cam sprocket? first vr6 so not 100% sure.basically i need some help sourcing some parts i need,sprocket pictured above and the boltthe casing which covers at top as the bolt has chewed mine up.also the chain tensioner bolt, the large 27mm bolt uptop with the copper washer.around 4 or 5 of the long bolts that hold the casing to the head. allen key ones. picture of casing im after:any advice on problems im likely to occur is great or anybody know where i can get any of the parts new or used.based in Rotherham South Yorkshire so if you know of any scrapyards local with a vr6 in let me know.cheers Link to post Share on other sites
legvw 0 Posted March 5, 2011 Report Share Posted March 5, 2011 Its a cam sprocket, but it looks like the center is missing, i think. It should look like the other 1.There are a few people breaking vr engine parts on the forum, worth a look. And if no-one comes up trumps with the bolts, vw or tps maybe your best bet. Link to post Share on other sites
