hilla 0 Posted January 12, 2011 Report Share Posted January 12, 2011 GOOD DAY GUYS, MY VR FEELS VERY UNSTABLE IN THE FRONT, THE STEERING IS LIGHT AND THE CAR FEELS AS IF IT IS FLOATING, I HAD THE 18" MAGS ON THE CAR, AND I REMOVED, THINKING IT WAS THE CULPRITS, BUT I STILL HAVE THE PROBLEM WITH THE OEM WHEELS. MY ALIGNMENT IS OUT BUT THE CAR NEVER DROVE LIKE THIS BEFORE, I REPLACED TIE ROD ENDS,CV JOINTS,LOWER CNTROL BUSHES, GEARBOX MOUNTINGS,COIL SPRINGS, SHOCK MOUNTINGS, BALL JOINTS. THE FEELING IS UNBEARABLE, WHEN I GO OVER ROAD SURFACES THAT IS UNEVEN, I DO NOT HAVE CONTROL OVER THE CAR EVEN @ A SPEED OF 60KM/H. PLEASE ANY HELP WILL B APPRECIATED, I REPLACED ALL THE ABOVE MENTIONED PARTS DUE TO MECHANICS NOT BIENG ABLE TO DIAGNOSE THE PROBLEM Link to post Share on other sites
bungy 2 Posted January 18, 2011 Report Share Posted January 18, 2011 No need for the caps whilst typing buddy....What camber have you got set at the front and what psi in your tyres. If everything has been fitted correctly i'd say your camber was out and causing the problem. Link to post Share on other sites
euanvr6 0 Posted March 30, 2011 Report Share Posted March 30, 2011 I had this problem the other day as my front wheels were cambered out at the top and catching my arches so i loosened the bolts on the suspension and pushed both front hubs all the way towards the center of the car,took it for a drive and it felt horrible and every little bump sent the steering loopy.I changed the camber again today pulling the hubs out slightly and it now feels a lot better Link to post Share on other sites
