probert993 0 Posted January 8, 2011 Report Share Posted January 8, 2011 my pump stopped makin its usual sounds when engine stops ages ago now, just bought a new one from gsf, connector on top was different so i used spade connectors to connect to top of pump, question is still cannont hear anything when engine is stopped so dont know now if its workin proper or if its just new and silent, or does engine have to be so hot til it kicks in etc , any ideas? Cheers Link to post Share on other sites
legvw 0 Posted January 8, 2011 Report Share Posted January 8, 2011 Check the fuses in the fan relay control module. Its on the right, under the expansion tank. Link to post Share on other sites
probert993 0 Posted January 8, 2011 Author Report Share Posted January 8, 2011 yeh checked them all ok, just wish i knew if was workin spent all that money too ! Link to post Share on other sites
legvw 0 Posted January 8, 2011 Report Share Posted January 8, 2011 I think it should 'run on' after the ignition is turned off, all the time, but i may be wrong, but i know Katies vr pump does.Have you tried unplugging it and testing to see if you get a reading arcoss the 2 wires, with ignition on and then off? It could be a fault in the wiring between the pump and the main engine plug just above it. Get a multimeter out and test the wires mate as i know they can become brittle after time. Link to post Share on other sites
sharma187 0 Posted January 19, 2011 Report Share Posted January 19, 2011 My one only rubs when the fan cuts in at 90Degrees Link to post Share on other sites
sharma187 0 Posted January 19, 2011 Report Share Posted January 19, 2011 Runs *** Link to post Share on other sites
