grom 0 Posted December 17, 2010 Report Share Posted December 17, 2010 got afew questions tonight cos Ive got alot of work to do tomorow so bare with me, you may see alot off posts by me pop up in different sub-forums.is it easy to swap over a steering wheel?dont want the airbag going off. do I just disconect the battery and undo some screws... simples? Link to post Share on other sites
Ben Seabrook 4 Posted December 17, 2010 Report Share Posted December 17, 2010 yup oretty much mate disconnect the battery then there are two grub screws on the back of the wheel undoe them pull off the front then remove the airbag very very carefully and their is a clip to undoe to remove that and then one big nut in the center - easier with two as someone can hold the wheel as you undoe the nut mate Link to post Share on other sites
grom 0 Posted December 17, 2010 Author Report Share Posted December 17, 2010 yup oretty much mate disconnect the battery then there are two grub screws on the back of the wheel undoe them pull off the front then remove the airbag very very carefully and their is a clip to undoe to remove that and then one big nut in the center - easier with two as someone can hold the wheel as you undoe the nut matelovin the new vid clip!whats a grub screw?is it still easy enough on your tod? Link to post Share on other sites
