My VR6 has been of the road a while and a few things have been changed recently
6 branch fitted
10mm HT leads
Its been started every other weekend .
So i started my VR6 up today and found that under acceleration it pauses for a few seconds and then the rpm picks up and its ok .(BMC draws air in the pauses and the as the RPM picks up it sucks more)
However it does it every time the throttle pedal is pressed .
Not sure what it could be ??
i have checked all HT leads are seated properly and the 6 branch is heat wrapped and fitted spot on .
PLEASE HELP IM NOT SURE WHAT TO DO !!
TB ?
Where do coil packs usually crack ?
Could it be due to spark plugs ?
TB Throttle Body.
Have you tried disconnecting a HT one at a time in turn to see if it runs differently. Also try disconnecting the MAF to see if it runs any different. Shame you are so far away as a look and listen usually helps loads.
Maf seem fine as i disconnected it from the plug and it still did the same !
Im thinkin of changing the lamda sensor as this looks very old plus i have a gauge for the air/fuel ratio and its stopped workin !!
anyone got one for sale cheap or best place to get one ???
UPDATE
bought a brand new lamda and its still doin the same thing
you press the peddle and it trys to stall however put the foot to the fllor it picks up and sounds healthy ! its the initial slight increase in the throttle and it trys to stall !!
PLEASE HELP
cleaned very carefully !
i have just spent an hour removing the spark plugs to check them and they were all black even tho they have been fitted about 500 miles ago. Also noticed the gap on them seem huge compared to the old ones that was removed. so i have cleaned the old ones up and re fitted them to try in the morning . At least its one more thing tried .
Update
Spark Plugs changed and still the same !
I am now wondering if its fueling right as i sounds like its struggling running.
I will change fuel filter and wondered what else to do such as injector cleaner etc
PLEASE HELP
