edalices 0 Posted June 17, 2010 Report Share Posted June 17, 2010 Hi all,I am running about 50-60% power right now, car has a good head. Power loss was fairly sudden symptom. Just sounds flat, actually fairly smooth, just no power, pretty difficult taking off, etc, occasionally seems to "float" a little better power for a couple seconds at a time.fuel consumption showing 50% higher than normal (15-16L/100km instead of 10-11L/100km)In past week I have:changed air&fuel filterslooked VERY hard for vac leaks and broken wiresswapped MAF with "known good one" from eBay (don't suspect it because absolutely no change to symptom)changed cat convertercurrent engine codes (after MAF replacement but I don't know how to reset them)00553 MAF sensor G70 open circuit/short with power intermittent00513 Engine speed sensor G28 no signalother history:coil pack replaced with brand new one 26,000 miles agohead replaced 50,000 miles agoplugs/wires changed 20,000 miles agoDoes anyone know if a crank sensor can cause this symptom? It doesn't seem likely to me. I am unemployed and don't want to keep throwing parts at it unless there is a reasonable chance of fix!Thanks a lot! Link to post Share on other sites
russj249 2 Posted June 17, 2010 Report Share Posted June 17, 2010 The engine speed sensor comes up as a fault if the engine isn't running at the time you pulled the fault codes out so don't worry about that.Seems to me that it is a MAF sensor fault.. have you checked the reading to see if there is an open circuit? Link to post Share on other sites
dave phillipson 0 Posted June 17, 2010 Report Share Posted June 17, 2010 Check intake pipe for cracks this will cause it to seem very flat as it's pulling in air after maf so giving a faulse reading! Same goes for inlet gaskets etc! Link to post Share on other sites
edalices 0 Posted June 18, 2010 Author Report Share Posted June 18, 2010 Thanks guys can you explain how "check the reading to see if there is an open circuit"? Am I checking each pin at car's MAF connector to ground looking for some continuity on most or all wires? Ignition off OK? Thanks, Ed Link to post Share on other sites
Pearsy47 1 Posted June 18, 2010 Report Share Posted June 18, 2010 i used to get that same code i have no idea what it could be ? Link to post Share on other sites
bungy 2 Posted June 18, 2010 Report Share Posted June 18, 2010 Check the wiring from your MAF back to source. Look for rubbing or chafing first and then continuity if that shows nothing. Link to post Share on other sites
edalices 0 Posted June 19, 2010 Author Report Share Posted June 19, 2010 Thanks guys After MAF, cat, filters and wires It was the screen on bottom of airbox scuzzed out, probably undercoating residue and everything else, even saw mouse debris up against it from the outside! Link to post Share on other sites
