'95 VR6 loss of power problem
Hi all,
I am running about 50-60% power right now, car has a good head. Power loss was fairly sudden symptom. Just sounds flat, actually fairly smooth, just no power, pretty difficult taking off, etc, occasionally seems to "float" a little better power for a couple seconds at a time.
fuel consumption showing 50% higher than normal (15-16L/100km instead of 10-11L/100km)
In past week I have:
changed air&fuel filters
looked VERY hard for vac leaks and broken wires
swapped MAF with "known good one" from eBay (don't suspect it because absolutely no change to symptom)
changed cat converter
current engine codes (after MAF replacement but I don't know how to reset them)
00553 MAF sensor G70 open circuit/short with power intermittent
00513 Engine speed sensor G28 no signal
other history:
coil pack replaced with brand new one 26,000 miles ago
head replaced 50,000 miles ago
plugs/wires changed 20,000 miles ago
Does anyone know if a crank sensor can cause this symptom? It doesn't seem likely to me. I am unemployed and don't want to keep throwing parts at it unless there is a reasonable chance of fix!
Thanks a lot!
The engine speed sensor comes up as a fault if the engine isn't running at the time you pulled the fault codes out so don't worry about that.
Seems to me that it is a MAF sensor fault.. have you checked the reading to see if there is an open circuit?
