Hi
I have noticed some times my car does not let me go in to gears properly, and my reverse gear some times plays up too, i have my clutch fully down when changing, but it sometimes crunches in to gears?
What do you guys reckon?
Cheers.
Me again haha
gear linkage bush is a fairly common problem and a cheap and easy fix, less than £10 for the repair kit at GSF I've heard.
The old ones crumble over time and cause it to slop around making gears abit hit and miss to find or sometimes even undrivable
Have a look at the gearbox mount and see if it looks like it's leaking
Do a clutch test, 30mph 5th gear, what happens, stuttering, stalling or pulling is ok, if the revs pick up easily the clutch is going
Transmission fluid may need a change.
That's most of the normal things I can think of off the top of my head
  • 3 weeks later...
