1996 mk3 VR6 ABS system not working
ah ok.. best thing to do is quickly replace the bulb then and try that to see if it stays on.. they are only about 50p if that.
The ABS bit on dash by lights just pops out and just check the connector is plugged in. If there is a fault somebody might have just disconected it so the light's not on, or the bulb might just have blown.
Not sure if the bulb needs to be working for the ABS to work. If somebody can help out with that as like the alternator charge system won't work if the light on dash has gone.
Let us know how you get on
