Fans not working (electric)
the fan? try putting direct voltage through the motor/fan, if it doesn't work/blow it's the fan/motor, if it does it's the connection between the controls and the fan, you would have to check the continuaty between the control and the fan. If this is ok i would suspect the control panel or relay if there is one these are the only things left, hope this helps. Please post outcome as always handy to know these things.
mine is a bit like this to i don't get level 1,2 or three but i get level 4 so if i want air then is like a hurricane, pisses me off a bit, weird thing is if its really really cold like -3 then they all work fine. don't really understand that bit.
