pete.stace81 0 Posted September 20, 2009 Report Share Posted September 20, 2009 Hi all, just become a vr6 golf owner mk3 and already having a major problem, can anyone help please?The VR6 wont turn over/ start at all.... all the lights come on, all the electrics work fine and the alarm is working also....It will bump start no issues and after running it for 20mins or so then it will fire up no problem but after left for few mins same problem again....please please please help as mssing out on valuble VR6 driving time....;(the car is on a p reg and is the highline model...Thanks in advance! Link to post Share on other sites
thegoth 5 Posted September 20, 2009 Report Share Posted September 20, 2009 hiya,you'll need to check to see if you are getting 12v to the starter's actuator during the times the it doesn't turn over.Starter is at the bottom of the engine, passanger side, front. It's got a fat starting current size cable bolted to the end of it and a red & black wire plugged in.If this wire is suppling voltage then it's the starter if not probably the ignition switch. Link to post Share on other sites
bungy 2 Posted September 20, 2009 Report Share Posted September 20, 2009 Same as above. Are you getting a click when you turn the key? Link to post Share on other sites
pete.stace81 0 Posted September 20, 2009 Author Report Share Posted September 20, 2009 thanks for your help! will get the mutimeter on it in the morning see what happens...no not getting a click when turning the key....i have just installed an amp for the front speakers but its only set on the minimum.... would this have killed it as it is all wired up correctly.....Many thanks Link to post Share on other sites
thegoth 5 Posted September 20, 2009 Report Share Posted September 20, 2009 shouldn't do. where have you wired the amp back to for power? Link to post Share on other sites
pete.stace81 0 Posted September 20, 2009 Author Report Share Posted September 20, 2009 wired direct to the battery.... Used a really good quality fitting kit (vibe) for the wiring - didnt think it would make a difference to the starter but thought id ask...is there any special type of ignition switch i need to get? found 1 on ebay for around a tenner...??!as the ignition is not even clicking do u think its the switch not the starter motor?Many thanks again for your help!! Link to post Share on other sites
thegoth 5 Posted September 20, 2009 Report Share Posted September 20, 2009 I doubt it will be the amp tehen. if you'd been playing behind the fuse/relay board it would be a different matter ;-)any mk3 should do, i'd have thought, if it turns out to be thatgotta get a meter on it to be sure. Link to post Share on other sites
pete.stace81 0 Posted September 20, 2009 Author Report Share Posted September 20, 2009 nice one! No not been playing with the fuses so will get a meter on it tom and hopefully shed some light on the problem.... fingers crossed!!Thanks for all ur help been well worth joining the owners club!will get a response posted asap when find the issue!! Link to post Share on other sites
bungy 2 Posted September 20, 2009 Report Share Posted September 20, 2009 When you turn the key does this not send power to a relay that in turn allows power to the starter? If you are not even getting the click, I would start at the starter relay. Check for power to if ignition to starter on. If the relay allows a start signal, then the solenoid on the starter motor and check for a good earth by connecting up a bypass. All of this is from experience on other cars and not mk3 specific so i'm sure someone can jump in if I've got it wrong. Link to post Share on other sites
thegoth 5 Posted September 20, 2009 Report Share Posted September 20, 2009 the only relay is the actuator in the starter. It's a direct link from the ignition switch to the starter. There isn't even a fuse! Although it does go via the back of fuse/relay board but it goes straight in and out. Link to post Share on other sites
jims13 6 Posted September 21, 2009 Report Share Posted September 21, 2009 did you say youve wired it directto the battery ??if so thats your problem.. the amp needs to be on a switched live.. otherwise battery will go flat after half hour or so Link to post Share on other sites
pete.stace81 0 Posted September 21, 2009 Author Report Share Posted September 21, 2009 hi, solved the problem.....Got the multimeter on the starter and found loose connection on it.....!!!Made sure it was in nice and tight and all is working now, crisis over!!Thanks again for all your help with the issue u have all been really useful! Keep up the good work, im off to go do some serious driving\!! Link to post Share on other sites
