Right here we go.
Turn the ignition on even when car is cold and the rad fans kick in and stay on. When I switch the ignition off with out starting the car the fans stay on for about 10mins after.
Got new temp switch and it still has not worked. Problem is its killing my battery.
Anybody got any ideas as its driving me mad.
Thanks in advance pete.
What temp switch you replaced?The one on the thermostat housing? Because i had a same problem and i run twice out of battery since i realised what was going on and i just changed the temp switch on the rad and everything now works just fine ;)
