VDub_Steve 1 Posted February 18, 2009 Report Share Posted February 18, 2009 At the title says lol. Started a few day ago when i acceleerate it would pull then flat spot then pull the flat spot is about 3k-4k and im gettin minced by astra sxi's any1 have a clue what it could be oh yh its idles fine and revs fine its only when im driving Link to post Share on other sites
VDub_Steve 1 Posted February 18, 2009 Author Report Share Posted February 18, 2009 BUMP Link to post Share on other sites
mike 6 Posted February 18, 2009 Report Share Posted February 18, 2009 could be anything mate, you need to getit on a vagcom...iv had simlar issues, turned out to be my ecu the first time and got a new one fitted...also maf can rob power Link to post Share on other sites
VDub_Steve 1 Posted February 18, 2009 Author Report Share Posted February 18, 2009 but surley if it was ecu it wouldnt idle same goes for maf Link to post Share on other sites
mike 6 Posted February 18, 2009 Report Share Posted February 18, 2009 get it on a vagcom mate, pretty sure mine iddled teh same with ecu faultly... robbed me of alot of power Link to post Share on other sites
VDub_Steve 1 Posted February 18, 2009 Author Report Share Posted February 18, 2009 ok where do i go that aint gonna be pricey??? Link to post Share on other sites
VDub_Steve 1 Posted February 19, 2009 Author Report Share Posted February 19, 2009 any1 else have n e ideas??? forgot to say it only happens when its warm Link to post Share on other sites
ip 0 Posted February 19, 2009 Report Share Posted February 19, 2009 VW Mike is right. Symptoms are too vague. Could genuinley be any of:MAF, Lambda, Temp Sensors, Injector failure, coil failure, ecu failure, cam position sensor failure ....... Anything really!If you own, or have access to, a laptop. Buy a vagcom interface from ebay (about £20) and then you can read any fault codes directly off the car yourself. This will save you a huge amount of time/money and you'll be able to get much better responses from forum users.If you are planning to keep your car for any time at all it will pay for itself easily and is a peice of piss to use (just plug in and go).Cheers,ip Link to post Share on other sites
mike 6 Posted February 19, 2009 Report Share Posted February 19, 2009 ok where do i go that aint gonna be pricey???well i take mine to midland vw and the vag com it free there to give you a quiote, might be too far for you...they suplied and fitted a used ecu and coded it for 150...but as above could be anything.... Link to post Share on other sites
