hi i just been cleaning bits on the car and when i removed the large air intake pipe that joins on to the throttle body, there was loads of oil inside the plastic pipe and inside the throttle body??? is this common and would it effect anything??
It happens sometimes' date=' normally condensed oil vapour from the breather pipe, just give it a good clean out and re-lube
HI xyber, you say relube but what part are you refering to and what would you use, im servicing my vr this weekend and want to give it a good going over so I will remve these pipes and do whats needed if ness
many thanks matt
