vr6power 1 Posted November 29, 2008 Report Share Posted November 29, 2008 as above just changed my timing chains but when i do the top tensioner bolt up the engine wont turn over. i loosen it off the engine turns over but oil pours out the tiny hole can any one help thanks alot Link to post Share on other sites
Dave Lea 4 Posted November 29, 2008 Report Share Posted November 29, 2008 wrong bolt is it the same lenth as te old one or have u just changed the chain and guids Link to post Share on other sites
krave 0 Posted November 29, 2008 Report Share Posted November 29, 2008 Some of these bolts you have to relieve pressure from the piston in the bolt. Have you done this? Link to post Share on other sites
vr6power 1 Posted November 29, 2008 Author Report Share Posted November 29, 2008 this is the first time i have done this i filled the bolt up with oil then fitted should i take the bolt out and just put it back in without oil in Link to post Share on other sites
krave 0 Posted November 29, 2008 Report Share Posted November 29, 2008 To bleed the older style tensioner, insert a thing wire into the bleed hole in the end of the plunger to activate the check valve inside and then press down on the plunger to compress it fully. Some people like to extend the tensioner slightly so that there is some tension on the upper chain when the engine is started the first time. If you want to do this, submerge the tensioner in oil and pull out on the plunger. Doing so with the tensioner submerged will ensure that oil and not air fills the tensioner. Make sure you do not extend the tensioner too far or too much tension may be applied to the upper tensioner rail, causing premature wear. Use an iterative trial and error process to find the appropriate plunger length. Link to post Share on other sites
vr6power 1 Posted November 29, 2008 Author Report Share Posted November 29, 2008 ok thanks alot il give it ago tomorrow thaks everyone Link to post Share on other sites
Udi Siag 0 Posted September 11, 2011 Report Share Posted September 11, 2011 To bleed the older style tensioner' date=' insert a thing wire into the bleed hole in the end of the plunger to activate the check valve inside and then press down on the plunger to compress it fully. Some people like to extend the tensioner slightly so that there is some tension on the upper chain when the engine is started the first time. If you want to do this, submerge the tensioner in oil and pull out on the plunger. Doing so with the tensioner submerged will ensure that oil and not air fills the tensioner. Make sure you do not extend the tensioner too far or too much tension may be applied to the upper tensioner rail, causing premature wear. Use an iterative trial and error process to find the appropriate plunger length.[/quote']hi there mate, i have a question . i change the chain tensioner screw with a used one 7 months ago . but lately i hear a noise when i start the car only in the morning. and also lately i hear the noise when the RPM around 2300 . could it be the chain tensioner screw again ?by the way i changed almost everything , and test the oil pressure and it was perfect . here's a video so u can listen to the noise . http://www.youtube.com/watch?v=m0j8l8d68kA Link to post Share on other sites
