Auxiliary Water Pump Question
Hello!
I have a presumably problem with Auxiliary Water Pump but first I need to know does the pump make some noise at all when working (buzzing or something like windscreen sprayer motor?). Mine makes no noise at all when ventilators are working...
hi, the easiest way to tell is turn on you're ignition on then off again and the pump should run for about ten mins, within that time have a listen at the pump or if the cooling sytem is cold hold the body of it, youshold feel it buzzing. if not check the fuses in the control unit that's under the coolant bottle
hi' date=' the easiest way to tell is turn on you're ignition on then off again and the pump should run for about ten mins, within that time have a listen at the pump or if the cooling sytem is cold hold the body of it, youshold feel it buzzing. if not check the fuses in the control unit that's under the coolant bottle
You mean that fuse? What there needs to be overlooked that I undrestand its okay? Metal clip needs to be in one piece?
