[moved] hay
lmao...
there a 17mm drain plug on the underside of the box and another one on the front which is used to check the fluid level (on flat ground the oil should just about dribble out of the plug-hole)
u only need £10 worth of oil from gsf to fill the box (2 litres) so its quite cheap to do an oil change
