dansnell 0 Posted September 26, 2008 Report Share Posted September 26, 2008 Hi ya everyone, my VR6 is making a horrible noise in and out of second gear, is it worth checking the gear oil? and if so where is it? Thanks guys Link to post Share on other sites
craggsy 91 Posted September 26, 2008 Report Share Posted September 26, 2008 In the gearbox mate........sorry couldnt help that Link to post Share on other sites
Karr-Man 0 Posted September 27, 2008 Report Share Posted September 27, 2008 lmao...there a 17mm drain plug on the underside of the box and another one on the front which is used to check the fluid level (on flat ground the oil should just about dribble out of the plug-hole)u only need £10 worth of oil from gsf to fill the box (2 litres) so its quite cheap to do an oil change Link to post Share on other sites
