ip 0 Posted August 30, 2008 Report Share Posted August 30, 2008 My rear turrets have started to creak and groan at low speeds when cornering or driving over uneven ground. The top mounts are only 9 months old and the shocks/springs are okay too. I've tried reseating the top mounts (loosened bolts and removed top rubber then reassembled and tightened back up) but this has not helped at all. These are the original shocks but it did it just the same with a set of coilovers that I temporarily tried out a couple of weeks back.Fairly new to suspension work so I'm not sure what else to try. Is itpossible to overtighten the top bolts? Should I try loosening them of a bit or greasing the rubbers?Any help gratefully recieved.Cheers,ip Link to post Share on other sites
jims13 6 Posted August 30, 2008 Report Share Posted August 30, 2008 i have this on the drivers side front, my top mounts aint much older than yours, but at a guess id say top mounts again...some of the pattern ones just dont last.. Link to post Share on other sites
ip 0 Posted August 31, 2008 Author Report Share Posted August 31, 2008 Sorted. Added a bit of grease to the top mounts themselves. Dead quiet. Link to post Share on other sites
