juliet 0 Posted June 30, 2008 Report Share Posted June 30, 2008 Iv recently purchased a engine fault code reader, which addmitadly came with a book with all the engine fault code in with a small discription next to them, Unfortunatly the description is indeed very brief and if i could just find a web site thread that explains the faults a little better this would be most appreciated. Mine came up with several some i erased some wont.ThanksBen Link to post Share on other sites
xyber 1 Posted June 30, 2008 Report Share Posted June 30, 2008 Google 'fault code' and what ever the code isie fault code 00533or register here http://www.gendan.co.uk/codebank/ Link to post Share on other sites
Charged VR 0 Posted June 30, 2008 Report Share Posted June 30, 2008 What Fault codes came up? Link to post Share on other sites
craggsy 91 Posted June 30, 2008 Report Share Posted June 30, 2008 Someone will know if you post fault code Link to post Share on other sites
juliet 0 Posted July 1, 2008 Author Report Share Posted July 1, 2008 Ok here goes, Fault codes are as follows00515005330051365535All will reset with the code reader i have but all appear after running the carThe book that came with the reader dosnt really explain in great detail what they meanAny help most appreciatedThanksBen ( homer ) hobson Link to post Share on other sites
juliet 0 Posted July 1, 2008 Author Report Share Posted July 1, 2008 Ps forgot to mention OBD1 early VR6 92. reason for getting code reader wanted one, got it cheap also has this hesitation problem that iv had from day one. Any suggestions on that one will really really make my day. Thought that maybe the reader might give me a clue only other bit is has early MAF 6 pin connector VW code 021 906 461 Bosch 0 280 213 021 which are like hens teeth or about £260 newThanksHomer Link to post Share on other sites
UnitedMotorsport 55 Posted July 1, 2008 Report Share Posted July 1, 2008 00513 is "crank sensor sees no signal", this will be because this is an OBD1 car, that this will always be there everytime you read the codes with the engine not running. If your engine starts, discard this one.00533 is Idle speed adaptation maximum limit exceeded or Minimum adaptation limit not reached.(sticky idle valve is likely)00515 is Cam position shaft sensor error, This will cause the ecu to run in batchfire mode, and itll pull the timing right off, does the engine feel 'Flat?'65535 is internal memory error, this is normally caused by someone trying to "chip" the ECU and messing it up, by not realising there are 'Checksumms' With in this memory Link to post Share on other sites
juliet 0 Posted July 1, 2008 Author Report Share Posted July 1, 2008 BrilliantYes the engine does indeed fell as flat as flat can be. To be perfectly honest when the engine is cold ( yes not recomended ) it goes like S&*T of a hot shovel but after it warms up you can suddenly fell it hesitatingbut also this car does indeed have a chip on it installed i might add by a repitible company could this also be cocking it upsome where, Also would mine have a cam sha#ft sensor it dosnt have a coil pack but a good old distributor.ThanksHomer Link to post Share on other sites
xyber 1 Posted July 1, 2008 Report Share Posted July 1, 2008 I cured my 00533 by wiping the throttle body out with isopropyl alcohol as it was cruded with oil Link to post Share on other sites
