Marky 0 Posted June 2, 2008 Report Share Posted June 2, 2008 Hi, its a 94 Golf, an OBD1 model, I replaced the coil pack a couple of weeks ago, but for the past few months I've always noticed the smell of petrol until the engine has got to operating temperature, so looks like a rich mixture? The engine doesn't stall, it runs fine just strong smell of petrol. There is no petrol smell if you do a warm start. The lamda sensor was replaced in December. Is the best bet to get someone to do engine diagnostics on it?Also, is there an engine management light on the dash? The instruction book doesn't show one in the warning lamps section, how would you know if there is an ecu problem? Link to post Share on other sites
xyber 1 Posted June 2, 2008 Report Share Posted June 2, 2008 yeah vag com it mate, itll only be something small, mine was doing it so on sat I replaced the MAF and blue coolant temp sensor and its sorted now and flies! Link to post Share on other sites
Marky 0 Posted June 2, 2008 Author Report Share Posted June 2, 2008 What do I need to do the diagnosis myself? Link to post Share on other sites
xyber 1 Posted June 2, 2008 Report Share Posted June 2, 2008 http://www.gendan.co.uk/product_GDVAG.html and the OBD1 adaptor http://www.gendan.co.uk/product_VAG2X2.htmlwell worth having, saves time and money in the long run Link to post Share on other sites
Marky 0 Posted June 2, 2008 Author Report Share Posted June 2, 2008 Cheers. Link to post Share on other sites
Marky 0 Posted June 23, 2008 Author Report Share Posted June 23, 2008 Had a look, turns out it has only been running on 5 cylinders!!! Replaced the blacked up spark plug but now its misfiring on that cylinder so I'm going to get the coil pack checked. Link to post Share on other sites
xyber 1 Posted June 23, 2008 Report Share Posted June 23, 2008 They are very picky about HT leads, wait till its dark, start the engine and mist the leads and coilpack with water and look for arching, could be just a cracked lead Link to post Share on other sites
